[GRASS-dev] libLAS on Ubuntu 14.04
Javier Martínez-López javi.martinez.lopez at gmail.com
Thu May 29 10:09:21 PDT 2014
I had the same problem with the latest grass 71 svn version (from
today) under ubuntu 14.04 and I certainly solved it installing
libboost-all-dev and the config option: --with-liblas=yes
--with-liblas-config=/usr/bin/liblas-config
Thank you and cheers,
Javier
On Fri, May 23, 2014 at 11:13 PM, Rashad M <mohammedrashadkm at gmail.com> wrote:
> Hi again!.
> Do you have ctest passed?
> For me i have:
> Test command:
> /home/rashad/Desktop/libLAS-1.7.0/build/bin/Release/liblas_test
> "/home/rashad/Desktop/libLAS-1.7.0/test/data"
> 1: Test timeout computed to be: 1500
> 1: libLAS Test Suite:
> 1: ==================
> 1: liblas::Bounds: ....
> 1: liblas::Error: ...
> 1: liblas::Header: ............
> 1: liblas::Point: ...................
> 1: liblas::Reader: ........
> 1: liblas::SpatialReference: .
> 1: liblas::VariableRecord: ......
> 1: liblas::Writer: ......
> 1: liblas::guid: .......
> 1: liblas::lasreader_iterator: ......................
> 1:
> 1: tests summary: ok:88
> 1/1 Test #1: liblas_test ......................   Passed    0.02 sec
> 100% tests passed, 0 tests failed out of 1
> If so you need update the test in grass configure. BTW. it seems like c
> library is not used anymore.You must check this with libLAS devs. But for
> now try updating configure test code
> On Fri, May 23, 2014 at 11:03 PM, Rashad M <mohammedrashadkm at gmail.com>
> wrote:
>> Much interesting why it ask for c++ when using C headers ?
>> On Fri, May 23, 2014 at 10:58 PM, Vaclav Petras <wenzeslaus at gmail.com>
>> wrote:
>>> On Fri, May 23, 2014 at 4:52 PM, Rashad M <mohammedrashadkm at gmail.com>
>>> wrote:
>>>> Hi Vaclav,
>>>> try linking to las_c instead of las
>>>> gcc liblastest.c -o liblastest -ggdb -L/usr/lib -llas_c
>>>> /usr/lib/libgdal.so /usr/lib/libgeotiff.so
>>>> /usr/lib/x86_64-linux-gnu/libtiff.so
>>>> boost and las.so not required here, i think
>>> Thanks but no success here.
>>>> On Fri, May 23, 2014 at 10:04 PM, Vaclav Petras <wenzeslaus at gmail.com>
>>>> wrote:
>>>>> On Fri, May 23, 2014 at 3:35 PM, Rashad M <mohammedrashadkm at gmail.com>
>>>>> wrote:
>>>>>> Hi Vaclav,
>>>>>> If it helps:  http://trac.osgeo.org/grass/ticket/2065
>>>>> Thanks, I tried to unify the variables (r57541 and the patch from
>>>>> #2065):
>>>>> CFLAGS="$CFLAGS $LIBLAS_CFLAGS $LIBLAS_INC"
>>>>> CPPFLAGS="$CPPFLAGS $LIBLAS_CPPFLAGS $LIBLAS_INC"
>>>>> but it did not help. I see that the ticket is closed and it puzzles me
>>>>> that it is not enough for me.
>>>>>> On Fri, May 23, 2014 at 9:25 PM, Vaclav Petras <wenzeslaus at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, May 23, 2014 at 2:53 PM, Glynn Clements
>>>>>>> <glynn at gclements.plus.com> wrote:
>>>>>>>> Vaclav Petras wrote:
>>>>>>>> > So the test failed with segmentation fault
>>>>>>>> Possibly due to linking with gcc rather than g++. But that doesn't
>>>>>>>> matter, as configure tests don't normally try to execute the program
>>>>>>>> (that doesn't work if you're cross-compiling); they only care
>>>>>>>> whether
>>>>>>>> linking succeeds.
>>>>>>> I have to remember this gcc vs g++ possible issue and that ./cofigure
>>>>>>> does not execute. However, it did not helped me now. My sample program still
>>>>>>> segfaults when compiled with g++.
>>>>> I've tried also cxxflags and a file with cpp extension:
>>>>> g++ liblastest.cpp -o liblastest -ggdb $(liblas-config --libs)
>>>>> $(liblas-config --includes) $(liblas-config --cxxflags)
>>>>> but it still segfaults (with and without -ggdb). Should I report this
>>>>> somewhere (Launchpad, libLAS)?
>>>>>>>> > but it would actually fail
>>>>>>>> > during compilation if I would use `liblas-config --libs` because
>>>>>>>> > the boost
>>>>>>>> > libraries are `libboost_program_options.so.1.54.0` on my computer
>>>>>>>> > while
>>>>>>>> > `liblas-config --libs` says just `libboost_program_options.so`
>>>>>>>> > (same for
>>>>>>>> > thread library).
>>>>>>>> You may need to install a -devel package, e.g. boost-devel or
>>>>>>>> whatever.
>>>>>>>> Typically, the unversioned symlink is in the -devel package, as it's
>>>>>>>> only needed for compiling programs which use the library; running
>>>>>>>> them
>>>>>>>> will use either the library itself or a symlink which includes at
>>>>>>>> least the major version number.
>>>>>>> I installed libboost-thread-dev and libboost-program-options-dev and
>>>>>>> compilation works with $(liblas-config --libs) $(liblas-config --includes).
>>>>>>> So, it should work in ./configure but the result is still "libLAS support:
>>>>>>> no".
>>>>>>>> Glynn Clements <glynn at gclements.plus.com>
>>>>>>> _______________________________________________
>>>>>>> grass-dev mailing list
>>>>>>> grass-dev at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>>>>>> Regards,
>>>>>>    Rashad
>>>> Regards,
>>>>    Rashad
>> Regards,
>>    Rashad
> Regards,
>    Rashad
