[GRASS-dev] libLAS on Ubuntu 14.04
Vaclav Petras wenzeslaus at gmail.com
Fri May 30 07:00:06 PDT 2014
On Thu, May 29, 2014 at 1:09 PM, Javier Martínez-López <
javi.martinez.lopez at gmail.com> wrote:
> Hi,
> I had the same problem with the latest grass 71 svn version (from
> today) under ubuntu 14.04 and I certainly solved it installing
> libboost-all-dev and the config option: --with-liblas=yes
> --with-liblas-config=/usr/bin/liblas-config
Thank you. This was very helpful. The problem was that I included only
in my ./configure call. I thought that this is enough. When I added
--with-liblas=yes
it started to work. After ./configure ... && make, I have r.in.lidar and
v.in.lidar.
I still have just libboost-thread-dev and libboost-program-options-dev, the
libboost-all-dev package is not necessary, although it is the simplest
option.
I don't understand the think with --with-liblas=yes, I really though I read
here that it is not necessary (once you have --with-liblas-config) and Yann
was saying that different combinations of --with-liblas* does not work for
him.
There is still the problem with different content of CFLAGS and CPPFLAGS
variables (r57541 and the patch from #2065) in ./configure and also I'm not
able to run the test program from ./configure myself. I don't know how this
is important.
Thanks all for help. I'll try this also on other computers with Ubuntu
14.04 and I'll let you know if it will not work.
Vaclav
On Thu, May 22, 2014 at 3:25 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> I was trying to compile GRASS with libLAS but ./configure says no.
> I used:
> and I have all liblas packages from standard Ubuntu 14.04 repository
(libLAS version is 1.7.0 which is the current stable release).
On Thu, May 22, 2014 at 8:47 PM, Yann Chemin <ychemin at gmail.com> wrote:
> I can confirm the issue,
> also by trying these configure options it is not helping:
> --with-liblas --with-liblas-config
> --with-liblas --with-liblas-config=/usr/bin/liblas-config
> --with-liblas=yes --with-liblas-config
> --with-liblas=yes --with-liblas-config=/usr/bin/liblas-config
> Also two targets are found, both valid (v1.7.0) and identical:
> whereis liblas-config
> liblas-config: /usr/bin/liblas-config /usr/bin/X11/liblas-config
> /usr/share/man/man1/liblas-config.1.gz
> $ ls -aslh /usr/bin/X11/liblas-config
> 4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/X11/liblas-config
> $ ls -aslh /usr/bin/liblas-config
> 4.0K -rwxr-xr-x 1 root root 2.5K Feb 26 14:43 /usr/bin/liblas-config
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140530/c63ebcdc/attachment.html>
