[GRASS-dev] Dead code
Glynn Clements
glynn at gclements.plus.com
Thu May 29 16:57:55 PDT 2014
The following directories contain code but aren't built:
display/d.colors
display/d.extract
display/d.measure
display/d.what.rast
display/d.what.vect
display/d.zoom
general/g.pnmcat
general/g.setproj
imagery/i.class
imagery/i.ortho.photo/i.ortho.init
imagery/i.ortho.photo/i.ortho.transform
imagery/i.points
imagery/i.vpoints
raster/r.digit
raster/r.grow
raster/r.le
raster/r.li/r.li.setup
raster/r.watershed/shed
vector/v.label.sa
vector/v.mapcalc
Are there plans to "resurrect" any of these within the foreseeable
future? If not, they should be removed.
Also, raster/wildfire contains just a README and a Makefile, the
actual modules (r.ros, r.spread, r.spreadpath) having been moved up
into the parent raster directory.
The Makefile serves no purpose, and the README (which contains a link
to sample data) won't be seen by end users; its content should
probably be added to the manual pages for the relevant modules.
Finally, I feel that v.in.dwg should be moved to addons.
