[GRASS-dev] Dead code
Markus Neteler
neteler at osgeo.org
Fri May 30 04:07:45 PDT 2014
On Fri, May 30, 2014 at 1:57 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> The following directories contain code but aren't built:
[no idea]
> imagery/i.ortho.photo/i.ortho.init
> imagery/i.ortho.photo/i.ortho.transform
i.ortho.photo should remain, I hope to get this updated to G7 at some point.
> imagery/i.points
> imagery/i.vpoints
... maybe no longer needed?
> raster/r.digit
.. a r.digit tool would be nice to have.
> raster/r.grow
> raster/r.le
> raster/r.li/r.li.setup
... all delete candidates.
> raster/r.watershed/shed
... dunno.
> vector/v.label.sa
... merge with v.label?
> vector/v.mapcalc
... dunno.
> Are there plans to "resurrect" any of these within the foreseeable
> future? If not, they should be removed.
Some yes, some no, see above.
> Also, raster/wildfire contains just a README and a Makefile, the
> actual modules (r.ros, r.spread, r.spreadpath) having been moved up
> into the parent raster directory.
.. sounds like leftover?
> The Makefile serves no purpose, and the README (which contains a link
> to sample data) won't be seen by end users; its content should
> probably be added to the manual pages for the relevant modules.
yes.
> Finally, I feel that v.in.dwg should be moved to addons.
yes.
my 0.02 cents
Markus
