[GRASS-dev] [GRASS GIS] #2300: v.out.ogr: spatialite support not working
trac at osgeo.org
Thu May 29 19:03:46 PDT 2014
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.4
Component: Vector | Version: svn-trunk
Keywords: v.out.ogr, spatialite | Platform: Linux
Cpu: x86-64 |
Comment(by hamish):
here is another possibility,
`"When creating a spatial table and recovering the geometry using the
RecoverGeometryColumn function if you don't specify the geometry column as
lower case you end up getting a 'violates Geometry constraint [geom-type
or SRID not allowed]' error."`
http://stackoverflow.com/questions/15203403/spatialite-v4-0-0
-recovergeometrycolumn-violates-geometry-constraint-geom-type
Ticket URL: <https://trac.osgeo.org/grass/ticket/2300#comment:3>
