[GRASS-dev] [GRASS GIS] #2300: v.out.ogr: spatialite support not working
GRASS GIS trac at osgeo.org
Thu May 29 20:26:18 PDT 2014
 Reporter:  hamish                 |       Owner:  grass-dev@…
     Type:  defect                 |      Status:  new
 Priority:  critical               |   Milestone:  6.4.4
Component:  Vector                 |     Version:  svn-trunk
 Keywords:  v.out.ogr, spatialite  |    Platform:  Linux
      Cpu:  x86-64                 |
Comment(by hamish):
 Replying to [ticket:2300 hamish]:
 > In the gdal-dev thread the solution was to pick the correct one
 > of OGR_G_SetPoint() vs. OGR_G_SetPoint_2D(), maybe that helps here?
 > the code seems suitably pointy, even if it is embedded in the "lines"
 > part of the code, but I wonder if 2D vs 3D definition is causing
 trouble?
 right, that's it. The following patch vs. devbr6 makes it work:
 Index: main.c
 --- main.c      (revision 59151)
 +++ main.c      (working copy)
 @@ -753,9 +753,13 @@
             else if ((type == GV_POINT) ||
                      ((type == GV_CENTROID) && (otype & GV_CENTROID))) {
                 Ogr_geometry = OGR_G_CreateGeometry(wkbPoint);
 -               OGR_G_AddPoint(Ogr_geometry, Points->x[0], Points->y[0],
 -                              Points->z[0]);
 +               if (Vect_is_3d(&In))
 +                   OGR_G_AddPoint(Ogr_geometry, Points->x[0],
 Points->y[0],
 +                                  Points->z[0]);
 +               else
 +                   OGR_G_AddPoint_2D(Ogr_geometry, Points->x[0],
 Points->y[0]);
             else {              /* GV_LINE or GV_BOUNDARY */
 but the v.out.ogr z-flag logic might require some modifications to that.
 (the force-2D flag in trunk makes a bit more sense, but also would need a
 different check for the flag)
 > Converting usgsgages to a 3D points map didn't help.
 but I don't think I used the -z flag... ? All ways need to be tested, and
 other geometry types also need to receive the same 2D vs 3D treatment I
 guess.
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2300#comment:4>
