[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Fri May 30 00:27:42 PDT 2014
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Default     |     Version:  svn-trunk
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  All         |
Comment(by pvanbosgeo):
 May I offer a suggestion as an user? Disabling hitherto default parameter
 settings are fairly important as they will break user-made scripts. It did
 for me, and it wasn't easy to find out why they didn't work anymore. More
 so because the | was still listed as the default in the help files.
 So, whenever such changes are made, it would be good to change it in the
 help file and/or put them on a list like
 http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures (but perhaps a
 separate list for the development version, don't know).
 I am fully aware that time may be an impediment (I am very grateful for
 all the time you are already putting into improving the software), and I
 know that by using the development version I run the risk of things
 breaking, but still, if possible such changes in the help file could be
 helpful and also make it easier to spot potential bugs, etc.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:8>
