[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Fri May 30 00:32:26 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: All |
Comment(by pvanbosgeo):
As an additional comment, wouldn't it be possible to simply change the
default, but keeping the | as an option? I for one always declare all
parameters in my scripts, even if I am using the default settings,
precisely to avoid problems if ever the default is changed. Of course,
that doesn't help when some options are removed altogether.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:9>
