[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Fri May 30 04:54:56 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: | Platform: MSWindows 7
Cpu: All |
Comment(by annakrat):
Replying to [comment:8 pvanbosgeo]:
> May I offer a suggestion as an user? Disabling hitherto default
parameter settings are fairly important as they will break user-made
scripts. It did for me, and it wasn't easy to find out why they didn't
work anymore. More so because the | was still listed as the default in the
help files.
Sorry for that but the intention wasn't to disable it but to fix it
(although it was more a workaround than fixing). Now I see what was wrong,
I expected r.stats, the underlying module, to have | as default separator
parameter but it has space instead (btw is there any reason for this
inconsistency?). My intention was to not include | in the parameters with
which r.stats is called (because that was causing problem) and instead
make r.stats use its default separator.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:10>
