[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Fri May 30 07:19:34 PDT 2014
 Reporter:  pvanbosgeo  |       Owner:  grass-dev@…
     Type:  defect      |      Status:  new
 Priority:  normal      |   Milestone:  7.0.0
Component:  Default     |     Version:  svn-trunk
 Keywords:              |    Platform:  MSWindows 7
      Cpu:  All         |
Comment(by annakrat):
 Replying to [comment:7 hcho]:
 > I didn't try on Windows, but I think this is a problem with wxGUI, not
 with r.out.xyz, so we should fix the wxGUI console. We cannot work around
 this issue for all other modules that have a separator option. Maybe,
 double quotes around a pipe?
 It's not problem of wxGUI but maybe of Python scripting library. Today's
 version of r.out.xyz on Windows gives this error when you specify | or you
 leave default:
 The syntax of the command is incorrect.
 Adding quotes around pipe (for example in ```_make_val``` function in
 grass.core) works but results in ```"|"``` as a separator (3 characters)
 which is wrong. So, now we have r.out.xyz broken on Windows. Any ideas?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:12>
