[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
trac at osgeo.org
Fri May 30 07:36:48 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-trunk
Keywords: separator, pipe, r.out.xyz, r.stats | Platform: MSWindows 7
Cpu: All |
Changes (by wenzeslaus):
* keywords: => separator, pipe, r.out.xyz, r.stats
Comment:
Replying to [comment:12 annakrat]:
> Any ideas?
* Use `separator=pipe` instead of `separator=|`, similarly to
`separator=space`.
* Fix G7:r.stats, the default separator for all other modules is a pipe.
(And than apply again the patch.)
* Another idea would be to use some other separator by default which
would discourage usage of pipe by MS Windows users (which anyway must be
very confused from that character, I would say). A space or comma could be
much natural separators (e.g., considering putting the data to some
spreadsheet or computational environment such as R). This does not solve
the actual problem but it might completely avoid it on MS Windows and user
of other systems can still use the pipe if they want.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:13>
