[GRASS-dev] [GRASS-SVN] r60613 - in grass/trunk/vector: v.db.connect v.out.ascii v.rectify v.vect.stats
Vaclav Petras
wenzeslaus at gmail.com
Fri May 30 10:40:05 PDT 2014
On Fri, May 30, 2014 at 11:54 AM, <svn_grass at osgeo.org> wrote:
> - if (strcmp(delim_opt->answer, "\\t") == 0)
> - *delim = G_store("\t");
About r60612 and r60613, they are great. But I just noted a changed
interface for some of the modules because they supported also `\t` for tab
besides `tab`.
Either parser should support this or this should go to the change of the
interface in 7 wiki page.
When we are on it what about \n, do we want this or not. I would say that
both \t and \n might be helpful but \n can be dangerous sometimes.
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140530/03abac1a/attachment.html>
