[GRASS-dev] [GRASS-SVN] r60613 - in grass/trunk/vector: v.db.connect v.out.ascii v.rectify v.vect.stats
Huidae Cho grass4u at gmail.com
Fri May 30 11:05:39 PDT 2014
Hi, G_option_to_separator supports tab, \\t, and newline. Do we need \\n? I
don't think so because we can use newline. Maybe delete \\t for consistency
and use tab only?
On May 30, 2014 1:40 PM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Fri, May 30, 2014 at 11:54 AM, <svn_grass at osgeo.org> wrote:
>> -    if (strcmp(delim_opt->answer, "\\t") == 0)
>> -       *delim = G_store("\t");
> About r60612 and r60613, they are great. But I just noted a changed
> interface for some of the modules because they supported also `\t` for tab
> besides `tab`.
> Either parser should support this or this should go to the change of the
> interface in 7 wiki page.
> When we are on it what about \n, do we want this or not. I would say that
> both \t and \n might be helpful but \n can be dangerous sometimes.
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140530/95d408fb/attachment-0001.html>
