[GRASS-dev] [GRASS GIS] #2228: g.mremove: add an option to use 'map name exclusion patterns' like is available in g.mlist
trac at osgeo.org
Fri May 30 12:14:06 PDT 2014
Reporter: pvanbosgeo | Owner: grass-dev@…
Type: enhancement | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: unspecified
Keywords: | Platform: All
Cpu: Unspecified |
Comment(by wenzeslaus):
Replying to [comment:2 hcho]:
> The attached g.mremove version addresses this issue and has the same
interface as g.mlist (including exclude=, but except for mapset=,
separator=, and output=, which are irrelevant). Please test it. I think we
should push this version to trunk and possibly relbr7.
> The attached version works like:
g.mremove type=rast pattern="{sanderson,brady}_*"
exclude="*_f{acc,dem},sanderson_fdir"
g.mremove type=rast,vect pattern="brady_basin"
Is multiple map input still supported? I'm not sure how to remove multiple
maps if I know their names considering that this version of `g.mremove` is
used and `g.remove` will be removed. Now I do:
g.remove rast="mapone,maptwo,mapthree,mapfour,...,mapfifty"
The use case is a clean up function called at the end of the script which
creates temporary maps.
Perhaps send also a diff for convenience of other who want to check your
suggestion quickly.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2228#comment:3>
