[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Fri May 30 22:12:08 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by glynn):
 Replying to [comment:14 hcho]:
 > separator=pipe is added in r60614. G_OPT_F_SEP defaults to "pipe", not
 to "|". I think it should fix the problem.
 It adds a few new ones, namely that Python scripts (which don't use
 G_option_to_separator()) are now trying to use the literal string "pipe"
 as a separator. E.g.
 $ echo "170.510125 -45.868537" | m.proj -i input=-
 WARNING: Invalid field separator, using 'p'
 -4813902.92p-9497864.79p0.00
 G_OPT_F_SEP is used in r.out.xyz, v.in.lines, r.tileset and m.proj.
 r.out.xyz shouldn't be a problem, as the option is simply being passed
 through to r.stats.
 The other three all use the option value.
 v.in.lines and m.proj explicitly understand space, tab and comma (although
 I'm not sure that they interpret tab correctly; they appear to treat it as
 a synonym for space).
 r.tileset doesn't understand any of the names, interpreting the value
 literally.
 Also, none of this changes the fact that there appears to be a bug
 somewhere. There '''shouldn't''' be any problems with using a literal
 vertical bar character. If there are such problems, they should be fixed,
 not simply worked around so that we can pretend there isn't a problem.
 While there are valid reasons for supporting "separator=pipe" (e.g. not
 forcing users to understand how quoting/escaping works in their preferred
 shell), if it results in the original problem being forgotten about, it
 may need to be reverted until the problem is fixed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:16>
