[GRASS-dev] libLAS on Ubuntu 14.04
Vaclav Petras
wenzeslaus at gmail.com
Sat May 31 06:56:01 PDT 2014
On Sat, May 31, 2014 at 9:32 AM, Yann Chemin <ychemin at gmail.com> wrote:
> OK it was that thanks Vaclav
> Summary:
> sudo apt-get install libboost-thread-dev,libboost-program-options-dev
> liblas-c-dev
> in configure options:
> --with-liblas-config=/usr/bin/liblas-config
> --with-liblas=yes
> I updated the wiki for 14.04 and added libLAS packages and added libLAS to
configure for GRASS 7. I think the page needs some refactoring. I have hard
time to navigate it when I understand most of the terms but the problem is
the high number of possibilities.
http://grasswiki.osgeo.org/wiki/Compile_and_Install_Ubuntu
> On 31/05/2014, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> > On Sat, May 31, 2014 at 9:23 AM, Yann Chemin <ychemin at gmail.com> wrote:
> >> configure:6266:32: fatal error: liblas/capi/liblas.h: No such file or
> >> directory
> >> #include <liblas/capi/liblas.h>
> > Hm, are you sure you have the liblas-c-dev package? And are you sure the
> > file liblas/capi/liblas.h is there (on include path, in case of the
> > liblas-c-dev package it should be /usr/include/liblas/capi/liblas.h)?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140531/3fd1e3d1/attachment-0001.html>
