[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
Huidae Cho grass4u at gmail.com
Sat May 31 07:18:49 PDT 2014
Check r60634. ^|& had to be escaped with ^^^.
>  Reporter:  pvanbosgeo                           |       Owner:  grass-dev@
>      Type:  defect                               |      Status:  new
>  Priority:  normal                               |   Milestone:  7.0.0
> Component:  Default                              |     Version:  svn-trunk
>  Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows
> 7
>       Cpu:  All                                  |
> Comment(by annakrat):
>  Replying to [comment:15 glynn]:
>  > Replying to [comment:12 annakrat]:
>  > > It's not problem of wxGUI but maybe of Python scripting library.
>  Today's version of r.out.xyz on Windows gives this error when you specify
>  | or you leave default:
>   The syntax of the command is incorrect.
>  > How are you running the script?
>  Sorry I forgot to mention it, I tried to run it from wxGUI and terminal
>  window and the error is the same. So I repeat it again, it's not the
>  problem of wxGUI.
>  > If a command is executed via e.g. grass.run_command(), Python's
>  subprocess.Popen() provides the necessary quoting.
>  Apparently not.
> Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:18>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140531/121d518b/attachment.html>
