[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Sat May 31 04:19:15 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by annakrat):
 Replying to [comment:15 glynn]:
 > Replying to [comment:12 annakrat]:
 > > It's not problem of wxGUI but maybe of Python scripting library.
 Today's version of r.out.xyz on Windows gives this error when you specify
 | or you leave default:
  The syntax of the command is incorrect.
 > How are you running the script?
 Sorry I forgot to mention it, I tried to run it from wxGUI and terminal
 window and the error is the same. So I repeat it again, it's not the
 problem of wxGUI.
 > If a command is executed via e.g. grass.run_command(), Python's
 subprocess.Popen() provides the necessary quoting.
 Apparently not.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:18>
