[GRASS-dev] weren't r.stream going to core? was: r.stream.* problems on Ubuntu when installed via g.extensions
Helmut Kudrnovsky
hellik at web.de
Sun Nov 2 13:52:28 PST 2014
Martin Landa wrote
> Hi,
> 2014-11-01 1:07 GMT+01:00 Markus Neteler <
> neteler@
>> Future fixes in trunk (i.e. GRASS GIS 7.1.svn) may be backported to
>> Addons at this point.
> we could probably also remove these modules from trunk and maintain
> them on one place only (addons for now, can be changed in the future).
> What do you think about that?
> Martin
+1 for maintaining in one place.
regarding winGRASS the situation is following:
- in trunk: all r.stream.* are in trunk, only r.stream.basins is moved to
addon
- in relbranch7: only r.stream.extract is there, all others are in addon
regarding trunk winGRASS there is some doubling of r.stream.*-modules. most
of them are in trunk svn, you can then install these tools again by
g.extension, although they are already there.
it's very confusing ...
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/weren-t-r-stream-going-to-core-was-r-stream-problems-on-Ubuntu-when-installed-via-g-extensions-tp5097129p5170845.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
