[GRASS-dev] weren't r.stream going to core? was: r.stream.* problems on Ubuntu when installed via g.extensions
Markus Neteler
neteler at osgeo.org
Sun Nov 2 14:26:50 PST 2014
On Sun, Nov 2, 2014 at 10:52 PM, Helmut Kudrnovsky <hellik at web.de> wrote:
> Martin Landa wrote
>> we could probably also remove these modules from trunk and maintain
>> them on one place only (addons for now, can be changed in the future).
>> What do you think about that?
yes, good point.
>> Martin
> +1 for maintaining in one place.
> regarding winGRASS the situation is following:
> - in trunk: all r.stream.* are in trunk, only r.stream.basins is moved to
> addon
> - in relbranch7: only r.stream.extract is there, all others are in addon
> regarding trunk winGRASS there is some doubling of r.stream.*-modules. most
> of them are in trunk svn, you can then install these tools again by
> g.extension, although they are already there.
> it's very confusing ...
Ok, now I have removed in r62560 all r.stream.* except for
r.stream.extract also from trunk (and before sync'ed trunk in r62558
and r62559 to the version in Addons which got moved therein from
relbranch7).
No more conflicting versions any more...
Markus
