[GRASS-dev] [GRASS GIS] #2258: t.create creates DB always in the PERMANENT
trac at osgeo.org
Tue Nov 4 07:38:04 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: defect | Status: new
Priority: blocker | Milestone: 7.0.0
Component: Temporal | Version: svn-releasebranch70
Keywords: t.register | Platform: Unspecified
Cpu: Unspecified |
Comment(by huhabla):
Replying to [comment:15 neteler]:
> Replying to [comment:14 huhabla]:
> > Work in progress. I have applied the patches from #2408 in r61956 and
r61957. This is the basis for a larger patch, that enables distributed
temporal datasets (patch is attached, but very experimental). I will
switch to mapset specific temporal databases in case the new approach
works stable.
> Is the attached patch the mentioned "larger patch"? What is the state of
this ticket?
I have improved the temporal framework in the last months in grass trunk
to use as default the distributed temporal database approach. It should be
fully functional right now. There are several gunittests in
temporal/t.connect/testsuite that tests the new temporal database
approach.
Please test and report any issues with the new approach.
I would like to backport all the modifications of the temporal framework
and temporal modules to grass 7.0 if everything works fine.
I hope that the gunittest framework will be backported as well.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2258#comment:16>
