[GRASS-dev] [GRASS GIS] #2472: v.in.lidar gives negative point count on large las files
trac at osgeo.org
Tue Nov 4 09:36:50 PST 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: v.in.lidar point initial count | Platform: Unspecified
Cpu: x86-64 |
Trying to use v.in.lidar to import points from an las file with 3531181701
points
v.in.lidar -o -b input=/gisdata/grass7/lidardir/big_lidar_file_ground.laz
output=whole_co_ground_pts
Over-riding projection check
Importing -763785595 points..
Seems to be importing so far..
Running GRASS 7.0 SVN snapshot from 10/25/14
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472>
