[GRASS-dev] [GRASS GIS] #2472: v.in.lidar gives negative point count on large las files
trac at osgeo.org
Fri Nov 7 02:26:59 PST 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: v.in.lidar point initial count | Platform: Unspecified
Cpu: x86-64 |
Comment(by mlennert):
Replying to [ticket:2472 dnewcomb]:
> Trying to use v.in.lidar to import points from an las file with
3531181701 points
> v.in.lidar -o -b
input=/gisdata/grass7/lidardir/big_lidar_file_ground.laz
output=whole_co_ground_pts
> Over-riding projection check
> Importing -763785595 points..
A sign of integer overflow. AFAICT, in this particular case this is just
in the message where a '%d' placeholder is used which represents a signed
int. But the count of the number of points is defined as unsigned int and
with larger files this will probably also overflow.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472#comment:2>
