[GRASS-dev] [GRASS GIS] #2472: v.in.lidar gives negative point count on large las files
trac at osgeo.org
Fri Nov 7 02:28:27 PST 2014
Reporter: dnewcomb | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Default | Version: svn-releasebranch70
Keywords: v.in.lidar point initial count | Platform: Unspecified
Cpu: x86-64 |
Comment(by mlennert):
Replying to [comment:1 dnewcomb]:
> v.in.lidar has been running now for 10 hours and is using 13 GB of RAM
for this instance. Write access to the sqlite database by other vector
operations is currently blocked.
Try importing with the -t flag to not create an attribute table. Or
possibly use PostgreSQL as a back end for the attributes.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2472#comment:3>
