[GRASS-dev] Makefile related problem? Re: [GRASS-user] Confused when using i.fusion.brovey
Nikos Alexandris nik at nikosalexandris.net
Sun Nov 9 13:01:49 PST 2014
Nikos Alexandris wrote:
> I have this script
> <https://github.com/NikosAlexandris/i.fusion.hpf.py>. My local
> Makefile, with which I am trying to compile currently, is:
>   MODULE_TOPDIR = ../..
>   PGM = i.fusion.hpf
>   ETCFILES = high_pass_filter constants
>   include $(MODULE_TOPDIR)/include/Make/Script.make
>   include $(MODULE_TOPDIR)/include/Make/Python.make
> * Is the order of entries in ETCFILES significant? (high_pass_filter
> needs stuff from constants)
> * While both files are to be found, after compilation, under
> </grass70/dist.x86_64-unknown-linux-gnu/etc/i.fusion.hpf>, the script
> runs fine only when executing it from *any*, if I understand
> correctly, directory in which the helper file(s)
> "high_pass_filter.py(c)" is(are) in.
> I can't work this out. Thank you, Nikos
Thanks to "r.in.wms", fixed by using this line:
+sys.path.insert(1, os.path.join(os.path.dirname(sys.path[0]), 'etc',
'r.in.wms'))
Nikos
