[GRASS-dev] Makefile related problem? Re: [GRASS-user] Confused when using i.fusion.brovey
Nikos Alexandris nik at nikosalexandris.net
Sun Nov 9 12:41:00 PST 2014
I have this script
<https://github.com/NikosAlexandris/i.fusion.hpf.py>. My local Makefile,
with which I am trying to compile currently, is:
   MODULE_TOPDIR = ../..
   PGM = i.fusion.hpf
   ETCFILES = high_pass_filter constants
   include $(MODULE_TOPDIR)/include/Make/Script.make
   include $(MODULE_TOPDIR)/include/Make/Python.make
* Is the order of entries in ETCFILES significant? (high_pass_filter
needs stuff from constants)
* While both files are to be found, after compilation, under
</grass70/dist.x86_64-unknown-linux-gnu/etc/i.fusion.hpf>, the script
runs fine only when executing it from *any*, if I understand correctly,
directory in which the helper file(s) "high_pass_filter.py(c)" is(are)
in.
I can't work this out. Thank you, Nikos
