[GRASS-dev] [GRASS-user] Confused when using i.fusion.brovey
Moritz Lennert
mlennert at club.worldonline.be
Sat Nov 8 02:23:42 PST 2014
On 07/11/14 21:17, Nikos Alexandris wrote:
> Meanwhile, although the script "compiles", I have a problem running the
> script when not executing it form inside its source directory. I have 2
> or 3 external files which I import in the main program -- those are not
> copied along with the main program in the target directory under
> "grass70/dist.x86_64-unknown-linux-gnu/scripts/". Need to figure out
> what is wrong.
This seems to be a more general problem, see [1] and [2].
Moritz
[1] https://trac.osgeo.org/grass/ticket/2480
[2] http://lists.osgeo.org/pipermail/grass-dev/2014-November/071571.html
