[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline
GRASS GIS trac at osgeo.org
Mon Nov 10 08:57:43 PST 2014
 Reporter:  baharmon        |       Owner:  grass-dev@…
     Type:  defect          |      Status:  new
 Priority:  normal          |   Milestone:  7.0.0
Component:  Raster          |     Version:  svn-trunk
 Keywords:  v.surf.bspline  |    Platform:  MSWindows 8
      Cpu:  OSX/Intel       |
Comment(by baharmon):
 Replying to [comment:6 baharmon]:
 > Replying to [comment:5 neteler]:
 > > If you can, please provide a North Carolina dataset example.
 > I used the nc_spm_08_grass7 dataset to recreate the issue. Here are the
 steps I took:
 > d.vect map=elev_lid792_bepts at PERMANENT
 > g.region vect=elev_lid792_bepts at PERMANENT res=1
 > v.surf.bspline --overwrite input=elev_lid792_bepts at PERMANENT
 raster_output=elev_lid792_bepts_bspline memory=12000
 > (Mon Nov 10 11:43:02 2014)
 > Initializing output...
 > Processing subregion 1 of 16...
 > Processing subregion 2 of 16...
 > Processing subregion 3 of 16...
 > Processing subregion 4 of 16...
 > Processing subregion 5 of 16...
 > Processing subregion 6 of 16...
 > Processing subregion 7 of 16...
 > Processing subregion 8 of 16...
 > Processing subregion 9 of 16...
 > Processing subregion 10 of 16...
 > Processing subregion 11 of 16...
 > Processing subregion 12 of 16...
 > Processing subregion 13 of 16...
 > Processing subregion 14 of 16...
 > Processing subregion 15 of 16...
 > Processing subregion 16 of 16...
 > WARNING: Unable to rename null file
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.1'
 to
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/cell_misc/elev_lid792_bepts_bspline/null':
 Permission denied
 > WARNING: Unable to rename cell file
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.0'
 to
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/fcell/elev_lid792_bepts_bspline':
 Permission denied
 > WARNING: Unable to write quant rules: raster map
 <elev_lid792_bepts_bspline> is integer
 > v.surf.bspline complete.
 > (Mon Nov 10 11:46:02 2014) Command finished (2 min 59 sec)
 Just wanted to note that I ran this again using the user1 mapset rather
 than from the PERMANENT mapset just to follow best practices. The result
 was the same:
 (Mon Nov 10 11:51:15 2014)
 (Mon Nov 10 11:51:16 2014) Command finished (0 sec)
 (Mon Nov 10 11:51:30 2014)
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.1'
 to
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/cell_misc/elev_lid792_bepts_bspline/null':
 Permission denied
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.0'
 to
 'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/fcell/elev_lid792_bepts_bspline':
 Permission denied
 (Mon Nov 10 11:54:28 2014) Command finished (2 min 58 sec)
 Command 'd.rast map=elev_lid792_bepts_bspline at user1' failed
 Details: Fontconfig error: Cannot load default config file
 Raster map <elev_lid792_bepts_bspline at user1>: format field
 in header file invalid
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:7>
