[GRASS-dev] [GRASS GIS] #2434: v.surf.bspline
trac at osgeo.org
Mon Nov 10 11:29:35 PST 2014
Reporter: baharmon | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Raster | Version: svn-trunk
Keywords: v.surf.bspline | Platform: MSWindows 8
Cpu: OSX/Intel |
Comment(by hellik):
Replying to [comment:7 baharmon]:
> Replying to [comment:6 baharmon]:
> > Replying to [comment:5 neteler]:
> > > If you can, please provide a North Carolina dataset example.
> > I used the nc_spm_08_grass7 dataset to recreate the issue. Here are
the steps I took:
> > d.vect map=elev_lid792_bepts at PERMANENT
> > g.region vect=elev_lid792_bepts at PERMANENT res=1
> > v.surf.bspline --overwrite input=elev_lid792_bepts at PERMANENT
raster_output=elev_lid792_bepts_bspline memory=12000
> > (Mon Nov 10 11:43:02 2014)
> > Initializing output...
> > Processing subregion 1 of 16...
> > Processing subregion 2 of 16...
> > Processing subregion 3 of 16...
> > Processing subregion 4 of 16...
> > Processing subregion 5 of 16...
> > Processing subregion 6 of 16...
> > Processing subregion 7 of 16...
> > Processing subregion 8 of 16...
> > Processing subregion 9 of 16...
> > Processing subregion 10 of 16...
> > Processing subregion 11 of 16...
> > Processing subregion 12 of 16...
> > Processing subregion 13 of 16...
> > Processing subregion 14 of 16...
> > Processing subregion 15 of 16...
> > Processing subregion 16 of 16...
> > WARNING: Unable to rename null file
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.1'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/cell_misc/elev_lid792_bepts_bspline/null':
Permission denied
> > WARNING: Unable to rename cell file
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/.tmp/unknown/7332.0'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/PERMANENT/fcell/elev_lid792_bepts_bspline':
Permission denied
> > WARNING: Unable to write quant rules: raster map
<elev_lid792_bepts_bspline> is integer
> > v.surf.bspline complete.
> > (Mon Nov 10 11:46:02 2014) Command finished (2 min 59 sec)
> Just wanted to note that I ran this again using the user1 mapset rather
than from the PERMANENT mapset just to follow best practices. The result
was the same:
> (Mon Nov 10 11:51:15 2014)
> (Mon Nov 10 11:51:16 2014) Command finished (0 sec)
> (Mon Nov 10 11:51:30 2014)
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.1'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/cell_misc/elev_lid792_bepts_bspline/null':
Permission denied
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/.tmp/unknown/7556.0'
to
'C:\Users\Brendan\Documents\grassdata/nc_spm_08_grass7/user1/fcell/elev_lid792_bepts_bspline':
Permission denied
> (Mon Nov 10 11:54:28 2014) Command finished (2 min 58 sec)
> Command 'd.rast map=elev_lid792_bepts_bspline at user1' failed
> Details: Fontconfig error: Cannot load default config file
> Raster map <elev_lid792_bepts_bspline at user1>: format field
> in header file invalid
confirmed here with:
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 62657
Erstellungsdatum: 2014-11-08
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
(Mon Nov 10 20:23:05 2014)
v.surf.bspline --verbose input=elev_lid792_bepts at PERMANENT
raster_output=mytestrast memory=10000
Input is 3D: using z-coordinates for approximation
Zellen für die Rasterkarte <mytestrast> werden interpoliert.
Initialisiere die Ausgabe...
Adjusted EW splines 150
Adjusted NS splines 150
8785 points found in this subregion
12132 points found in this subregion
11562 points found in this subregion
9385 points found in this subregion
10376 points found in this subregion
14703 points found in this subregion
14656 points found in this subregion
10855 points found in this subregion
13453 points found in this subregion
15950 points found in this subregion
16042 points found in this subregion
11484 points found in this subregion
7861 points found in this subregion
9337 points found in this subregion
9184 points found in this subregion
6968 points found in this subregion
Schreibe Ausgabe...
'C:\grassdata/nc_spm_08_grass7/testspine/.tmp/unknown/7528.1' to
'C:\grassdata/nc_spm_08_grass7/testspine/cell_misc/mytestrast/null':
Permission denied
'C:\grassdata/nc_spm_08_grass7/testspine/.tmp/unknown/7528.0' to
'C:\grassdata/nc_spm_08_grass7/testspine/fcell/mytestrast': Permission
denied
WARNING: Unable to write quant rules: raster map <mytestrast> is integer
v.surf.bspline komplett.
(Mon Nov 10 20:26:54 2014) Befehl ausgeführt (3 Min 48 Sek)
could it be that the files aren't closed?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2434#comment:8>
