[GRASS-dev] How to check if a vector map is multi-layer?
Luca Delucchi lucadeluge at gmail.com
Wed Nov 12 01:31:10 PST 2014
On 1 November 2014 23:34, Markus Metz <markus.metz.giswork at gmail.com> wrote:
> My previous patch did not work for me, but the attached patch
> gguirlisetup.patch3 works for me now. Please test.
I improved you patch adding a new combobox to choose the layer number.
I have some problems with wxpython:
- I added two GError (if the vector has no areas or if the vector has
no dblinks), but when they appear they are back to the layertree, I
tried to close the layertree before using Dismiss() but it return me
and error
- I'm not able to cleanup the layer number combox if the vector is
without dblinks o without areas
some wxpython expert could check the new patch?
thanks
> Markus M
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141112/95a54105/attachment-0001.obj>
