[GRASS-dev] How to check if a vector map is multi-layer?
Anna Petrášová
kratochanna at gmail.com
Wed Nov 12 17:47:45 PST 2014
On Wed, Nov 12, 2014 at 4:31 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi,
> On 1 November 2014 23:34, Markus Metz <markus.metz.giswork at gmail.com>
> wrote:
> > My previous patch did not work for me, but the attached patch
> > gguirlisetup.patch3 works for me now. Please test.
Hi Luca,
> I improved you patch adding a new combobox to choose the layer number.
> I have some problems with wxpython:
> - I added two GError (if the vector has no areas or if the vector has
> no dblinks), but when they appear they are back to the layertree, I
> tried to close the layertree before using Dismiss() but it return me
> and error
- I'm not able to cleanup the layer number combox if the vector is
> without dblinks o without areas
> can you try this new version? I also did some changes for wxPython 3
compatibility
Anna
some wxpython expert could check the new patch?
> thanks
> > Markus M
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141112/a8c5f402/attachment.html>
Index: gui/wxpython/rlisetup/functions.py
--- gui/wxpython/rlisetup/functions.py (revision 62651)
+++ gui/wxpython/rlisetup/functions.py (working copy)
@@ -77,18 +77,35 @@
return False
-def convertFeature(vect, outrast, cat, origrast):
+def convertFeature(vect, outrast, cat, origrast, layer='1', overwrite=False):
"""Convert a single feature to a raster"""
tmp_vect = "tmp_{rast}".format(rast=outrast)
- grass.run_command('v.extract', input=vect, output=tmp_vect, cats=cat,
- overwrite=True, quiet=True)
- grass.run_command('g.region', vect=tmp_vect, align=origrast)
- grass.run_command('v.to.rast', input=vect, output=outrast, use='cat',
- cats=cat, overwrite=True, quiet=True)
+ grass.run_command('v.extract', input=vect, cats=cat, type='area',
+ layer=layer, output=tmp_vect, flags='d',
+ overwrite=overwrite, quiet=True)
+ grass.run_command('g.region', rast=origrast)
+ grass.run_command('g.region', vect=tmp_vect)
+ grass.run_command('g.region', align=origrast)
+ grass.run_command('v.to.rast', input=tmp_vect, type='area',
+ layer=layer, use='val', value=cat, output=outrast,
grass.run_command('g.remove', flags='f', type='vect',
name=tmp_vect, quiet=True)
+def obtainCategories(vector, layer='1'):
+ """This function returns a list of categories for all areas in
+ the given layer"""
+ vect_cats = []
+ vc = grass.read_command('v.category', input=vector, layer=layer,
+ option='print', type='centroid')
+ for lc in vc.splitlines():
+ for cat in lc.split('/'):
+ vect_cats.append(int(cat))
+ return sorted(set(vect_cats))
def obtainAreaVector(outrast):
"""Create the string for configuration file"""
reg = grass.region()
@@ -99,7 +116,7 @@
w=reg['w'])
-def sampleAreaVector(vect, rast, vect_cats, progDialog=None):
+def sampleAreaVector(vect, rast, vect_cats, layer='1', progDialog=None):
"""Create the strings to add to the configuration file using vector"""
areanum = len(vect_cats)
output = []
@@ -108,9 +125,9 @@
GError(message=_("The polygon seems to have 0 areas"))
return None
for n in range(areanum):
- cat = vect_cats[n]
+ cat = str(vect_cats[n])
rast_name = "{name}_{cat}".format(name=vect.split('@')[0], cat=cat)
- convertFeature(vect, rast_name, cat, rast)
+ convertFeature(vect, rast_name, cat, rast, layer=layer)
output.append(obtainAreaVector(rast_name))
if progDialog:
progDialog.Update(n)
Index: gui/wxpython/rlisetup/wizard.py
--- gui/wxpython/rlisetup/wizard.py (revision 62651)
+++ gui/wxpython/rlisetup/wizard.py (working copy)
@@ -33,7 +33,11 @@
from rlisetup.sampling_frame import RLiSetupMapPanel
from grass.script import core as grass
from grass.script import raster as grast
-from functions import SamplingType, sampleAreaVector, convertFeature, obtainAreaVector
+from grass.script import vector as gvect
+from grass.exceptions import CalledModuleError
+from functions import SamplingType, sampleAreaVector, convertFeature
+from functions import obtainAreaVector, obtainCategories
from core.gcmd import GError, GMessage, RunCommand
@@ -194,21 +198,21 @@
self.SF_W = newreg['w'] # set env(SF_W) $w
self.SF_Y = abs(round(self.gregion['n'] - newreg['n']) / newreg['nsres'])
-# set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
+# set env(SF_Y) [expr abs(round(($s_n - $n) / $nres)) ]
self.SF_X = abs(round(self.gregion['w'] - newreg['w']) / newreg['ewres'])
-# set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
+# set env(SF_X) [expr abs(round(($s_w - $w) / $sres)) ]
self.SF_RL = abs(round(newreg['n'] - newreg['s']) / newreg['nsres'])
-# set env(SF_RL) [expr abs(round(($n - $s) / $nres)) ]
+# set env(SF_RL) [expr abs(round(($n - $s) / $nres)) ]
self.SF_CL = abs(round(newreg['e'] - newreg['w']) / newreg['ewres'])
-# set env(SF_CL) [expr abs(round(($e - $w) / $sres)) ]
+# set env(SF_CL) [expr abs(round(($e - $w) / $sres)) ]
self.per_x = float(self.SF_X) / float(self.rasterinfo['cols'])
-# double($env(SF_X)) / double($cols)
+# double($env(SF_X)) / double($cols)
self.per_y = float(self.SF_Y) / float(self.rasterinfo['rows'])
-# double($env(SF_Y)) / double($rows)
+# double($env(SF_Y)) / double($rows)
self.per_rl = float(self.SF_RL) / float(self.rasterinfo['rows'])
-# double($env(SF_RL)) / double($rows)
+# double($env(SF_RL)) / double($rows)
self.per_cl = float(self.SF_CL) / float(self.rasterinfo['cols'])
-# double($env(SF_CL)) / double($cols)
+# double($env(SF_CL)) / double($cols)
fil.write("SAMPLINGFRAME %r|%r|%r|%r\n" % (self.per_x, self.per_y,
self.per_rl, self.per_cl))
@@ -463,6 +467,15 @@
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
self.sizer.Add(item=self.vectselect, border=5, pos=(2, 1),
+ #vector layer
+ self.vectlaylabel = wx.StaticText(parent=self, id=wx.ID_ANY,
+ label=_('Vector map layer to use to select areas'))
+ self.vectlayer = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ size=(250, -1))
+ self.sizer.Add(item=self.vectlaylabel, border=5, pos=(3, 0),
+ flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
+ self.sizer.Add(item=self.vectlayer, border=5, pos=(3, 1),
#define sampling region
self.sampling_reg = wx.RadioBox(parent=self, id=wx.ID_ANY,
label=" %s " % _("Define sampling "
@@ -475,7 +488,13 @@
self.sizer.Add(item=self.sampling_reg,
flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
- pos=(4, 0), span=(1, 2))
+ pos=(5, 0), span=(1, 2))
+ self.infoError = wx.StaticText(self, label='')
+ self.infoError.SetForegroundColour(wx.RED)
+ self.sizer.Add(item=self.infoError,
+ flag=wx.ALIGN_CENTER | wx.ALL | wx.EXPAND, border=5,
+ pos=(6, 0), span=(1, 2))
#bindings
self.sampling_reg.Bind(wx.EVT_RADIOBOX, self.OnSampling)
self.newconftxt.Bind(wx.EVT_KILL_FOCUS, self.OnName)
@@ -482,6 +501,7 @@
self.newconftxt.Bind(wx.EVT_TEXT, self.OnNameChanged)
self.vectselect.Bind(wx.EVT_TEXT, self.OnVector)
self.mapselect.Bind(wx.EVT_TEXT, self.OnRast)
+ self.vectlayer.Bind(wx.EVT_TEXT, self.OnLayer)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
@@ -515,16 +535,41 @@
def OnRast(self, event):
"""Sets raster map"""
- self.rast = event.GetString()
+ self.rast = self.mapselect.GetValue()
next = wx.FindWindowById(wx.ID_FORWARD)
next.Enable(self.CheckInput())
def OnVector(self, event):
"""Sets vector map"""
- self.vect = event.GetString()
+ self.vect = self.vectselect.GetValue()
+ if self.vect:
+ check, layers = self.CheckVector(self.vect)
+ if check:
+ self.vectlayer.SetItems(layers)
+ self.vectlayer.SetSelection(0)
+ self.vectorlayer = self.vectlayer.GetValue()
+ self.infoError.SetLabel('')
+ else:
+ self.vectlayer.Clear()
+ self.vectlayer.SetValue('')
+ self.vect = ''
+ else:
+ def OnLayer(self, event):
+ try:
+ except:
+ self.vectorlayer = None
+ next = wx.FindWindowById(wx.ID_FORWARD)
+ next.Enable(self.CheckInput())
def OnEnterPage(self, event):
"""Sets the default values, for the entire map
@@ -533,6 +578,32 @@
wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable,
self.CheckInput())
+ def CheckVector(self, vector):
+ """Check if the type of vector is area and return the number of
+ vector's layer"""
+ try:
+ areas = gvect.vector_info_topo(vector)['areas']
+ except CalledModuleError:
+ self.infoError.SetLabel(_("Vector %s was not found, please "
+ "select another vector") % vector)
+ return False, []
+ if areas == 0:
+ self.infoError.SetLabel(_("Vector %s has no areas, please "
+ return False, []
+ links = gvect.vector_info(vector)['num_dblinks']
+ if links == 0:
+ self.infoError.SetLabel(_("Vector %s has no table connected, please "
+ return False, []
+ elif links > 0:
+ layers = []
+ for i in range(1, links + 1):
+ layers.append(str(i))
+ return True, layers
+ else:
+ return False, []
def CheckInput(self):
"""Check input fields.
@@ -539,7 +610,6 @@
:return: True if configuration file is given and raster xor vector map,
False otherwise
- #R#return bool(self.conf_name and (bool(self.rast) != bool(self.vect)))
return bool(self.conf_name and bool(self.rast))
def OnExitPage(self, event=None):
@@ -801,10 +871,10 @@
def OnNumRegions(self, event):
"""Obtain the number of regions"""
- if event.GetString():
+ if self.regionNumTxt.GetValue():
self.SetNext(self.parent.regions)
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
- self.numregions = event.GetString()
+ self.numregions = self.regionNumTxt.GetValue()
else:
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
@@ -882,9 +952,9 @@
self.sizer.Hide(self.regionBox)
self.sizer.Hide(self.areaPanel)
self.SetNext(self.parent.summarypage)
- vect_cats = sorted(set(grass.parse_command('v.category', input=self.parent.startpage.vect,
- option='print',
- type='centroid').keys()))
+ vect_cats = obtainCategories(self.parent.startpage.vect, self.vectorlayer)
self._progressDlg = wx.ProgressDialog(title=_("Analysing vector"),
message="Analysing vector",
maximum=len(vect_cats),
@@ -896,6 +966,7 @@
self.parent.msAreaList = sampleAreaVector(self.parent.startpage.vect,
self.parent.startpage.rast,
vect_cats,
+ self.parent.startpage.vectorlayer,
self._progressDlg)
grass.del_temp_region()
if self.parent.msAreaList:
@@ -1150,16 +1221,16 @@
self.panelSizer.Layout()
def OnWidth(self, event):
- self.width = event.GetString()
+ self.width = self.widthTxt.GetValue()
def OnHeight(self, event):
- self.height = event.GetString()
+ self.height = self.heightTxt.GetValue()
def OnDistr1(self, event):
- self.distr1 = event.GetString()
+ self.distr1 = self.distr1Txt.GetValue()
def OnDistr2(self, event):
- self.distr2 = event.GetString()
+ self.distr2 = self.distr2Txt.GetValue()
class MovingKeyPage(TitledPage):
@@ -1239,12 +1310,12 @@
return bool(self.width and bool(self.height))
@@ -1339,10 +1410,10 @@
"""Set the number of region"""
self.SetNext(self.parent.drawsampleunitspage)
else:
@@ -1479,7 +1550,8 @@
cat = self.vect_cats[self.areascount]
self.outname = "{name}_{cat}".format(name=self.vect.split('@')[0],
cat=cat)
- convertFeature(self.vect, self.outname, cat, self.rast)
+ convertFeature(self.vect, self.outname, cat, self.rast,
+ layer=self.vectlayer)
cmdlistcat = ['d.rast', 'map=%s' % self.outname]
self.map_.AddLayer(ltype='raster', command=cmdlistcat, active=True,
name=self.outname, hidden=False, opacity=1.0,
@@ -1504,10 +1576,8 @@
self.rast = self.parent.startpage.rast
self.vect = self.parent.startpage.vect
- self.vect_cats = sorted(set(grass.parse_command('v.category',
- input=self.vect,
- type='centroid',
- option='print').keys()))
+ self.vect_cats = obtainCategories(self.vect, layer=self.vectlayer)
self.areanum = len(self.vect_cats)
if self.areanum == 0:
GError(parent=self, message=_("The polygon seems to have 0 areas"))
