[GRASS-dev] Backport gunittest and tests to 7.0?
Sören Gebbert
soerengebbert at googlemail.com
Wed Nov 12 08:28:36 PST 2014
Hi Vaclav,
i think the testing framework should go into 7.0.0 directly. Since, as
Pietro mentioned, it will not harm GRASS users. IMHO the testing
framework is a key feature, very valuable, it works well and is
utterly useful to detect backport issues. Hence, using the testing
framework a new release policy may be to reduce test failures to zero
on Linux platforms.
Best regards
Soeren
2014-11-11 23:32 GMT+01:00 Vaclav Petras <wenzeslaus at gmail.com>:
> On Tue, Nov 11, 2014 at 5:05 PM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> I don't understand if gunittest will be backported before 7.0 release,
>> if we backport we can leave that line, otherwise it should be removed
> I also don't know. It is an addition or feature, so it should not (doesn't
> have to) go to release. It is nor really mature either, although it
> apparently runs and works. The distribution is still not solved. Will the
> tests be included in installation? What about compiled C test programs (now
> compiled and added to standard modules)? So far, it has been tested just on
> Ubuntu as far as I know. (More discussion on that should be on GSoC project
> page)
> From the point of view of testing, it would be good to have it in release
> branch as soon as possible, so I don't know.
> Maybe it can go to GRASS GIS 7.0.1 but not to 7.0.0.
> Vaclav
