[GRASS-dev] G_OPT_R_MAP vs G_OPT_R_INPUT
Moritz Lennert mlennert at club.worldonline.be
Fri Nov 14 05:45:14 PST 2014
On 14/11/14 14:25, Benjamin Ducke wrote:
> On 14/11/14 14:14, Helmut Kudrnovsky wrote:
>> NikosAlexandris wrote
>>> What is the difference between G_OPT_R_MAP and G_OPT_R_INPUT? Which and
>>> why should I prefer for my script(s)?
>>> Is there a step-by-step run-through of all options for composing header
>>> definitions?
>>> Nikos
>>> grass-dev mailing list
>>> grass-dev at .osgeo
>>> http://lists.osgeo.org/mailman/listinfo/grass-dev
>> see
>> http://grass.osgeo.org/programming7/gis_8h.html#a5521b5269c52afe64e5051348b08fc69
> But that table doesn't really answer the question,
> does it? For both "G_OPT_R_INPUT" and "G_OPT_R_MAP"
> it lists "old input raster map". AFAIU, "G_OPT_R_MAP"
> is for modules that use only one input raster map.
> In those cases, the corresponding input option should
> be named "map=". "G_OPT_R_INPUT" would then be for
> modules that have either several raster map inputs or
> raster and vector maps as inputs. The corresponding
> input options would then be called "raster=" and
> "vector=" in case of exactly one raster and one vector
> input map. Further special cases are covered by
> "G_OPT_R_BASE", "G_OPT_R_ELEV", etc.: They all exist
> for semantical purposes. All of them stand for raster
> input maps.
I've always understood the difference between MAP and INPUT as
- MAP: used for modules which treat a map, but do not have input+output
logic (e.g. r.category, r.colors, etc)
- INPUT: used for modules that have input + output logic (r.cost,
r.mfilter, etc)
The difference between one or multiple inputs is covered by
G_OPT_R_INPUT vs G_OPT_R_INPUTS.
Moritz
