[GRASS-dev] grass7 addon python script - finishes in normal and --verbose mode, but not in --quiet mode
Anna Petrášová
kratochanna at gmail.com
Fri Nov 14 06:47:33 PST 2014
On Fri, Nov 14, 2014 at 6:37 AM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 14/11/14 10:25, Helmut Kudrnovsky wrote:
>> Anna Petrášová wrote
>>>> but in --quiet mode it fails with:
>>>> v.fixed.segmentpoints --quiet vector=iselflipped at myricaria cat=1
>>>> dir=C:\tmp\grassscript distance=25000
>>>> Traceback (most recent call last):
>>>> File "C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scr
>>>> ipts/v.fixed.segmentpoints.py", line 226, in
>>> <module>
>>>> sys.exit(main())
>>>> ipts/v.fixed.segmentpoints.py", line 100, in main
>>>> vector_line_length =
>>>> float(tmp.split('\n')[1].split('|')[1])
>>>> IndexError: list index out of range
>>>> (Thu Nov 13 21:40:08 2014) Befehl ausgeführt (2 Sek)
>>>> any idea?
>>> Could you try to print tmp with and without quiet?
>> http://trac.osgeo.org/grass/browser/grass-addons/grass7/
>> vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py#L102
>> 102 # Read length
>> 103 tmp = grass.read_command('v.to.db', map = voutline,
>> 104 type = 'line',
>> 105 layer = 1,
>> 106 qlayer = 1,
>> 107 option = 'length',
>> 108 units = 'meters',
>> 109 column = 'vlength',
>> 110 flags = 'p')
>> 111 vector_line_length = float(tmp.split('\n')[1].split('|')[1])
>> 112
>> 113 # Print vector line length
>> 114 grass.message( "Vector line length in meter:" )
>> 115 grass.message( vector_line_length )
>> 116 grass.message( "----" )
>> it's just to get the length of the vector line for further calculations:
>> in normal and verbose mode:
>> Lese Objekte...
>> 58858.3366368
>> as Moritz points out, it seems quiet mode suppresses the access to the
>> output of grass.read_command; his solution/workaround with GRASS_VERBOSE
>> env
>> variable seems not to work here on my side.
> I'm afraid that --quiet supersedes any settings in the code, but am not
> sure.
So how about setting quiet=False when calling v.to.db? Anyway I don't
think quiet causes read_command to be completely silent, just run
grass.read_command('r.info', map='elevation', flags='g', quiet=True)
and it gives output as expected.
> Moritz
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141114/0173e61e/attachment-0001.html>
