[GRASS-dev] grass7 addon python script - finishes in normal and --verbose mode, but not in --quiet mode
Anna Petrášová
kratochanna at gmail.com
Fri Nov 14 07:05:26 PST 2014
On Fri, Nov 14, 2014 at 9:47 AM, Anna Petrášová <kratochanna at gmail.com>
wrote:
> On Fri, Nov 14, 2014 at 6:37 AM, Moritz Lennert <
> mlennert at club.worldonline.be> wrote:
>> On 14/11/14 10:25, Helmut Kudrnovsky wrote:
>>> Anna Petrášová wrote
>>>>> but in --quiet mode it fails with:
>>>>> v.fixed.segmentpoints --quiet vector=iselflipped at myricaria cat=1
>>>>> dir=C:\tmp\grassscript distance=25000
>>>>> Traceback (most recent call last):
>>>>> File "C:\Users\myricaria\AppData\Roaming\GRASS7\addons/scr
>>>>> ipts/v.fixed.segmentpoints.py", line 226, in
>>>> <module>
>>>>> sys.exit(main())
>>>>> ipts/v.fixed.segmentpoints.py", line 100, in main
>>>>> vector_line_length =
>>>>> float(tmp.split('\n')[1].split('|')[1])
>>>>> IndexError: list index out of range
>>>>> (Thu Nov 13 21:40:08 2014) Befehl ausgeführt (2 Sek)
>>>>> any idea?
>>>> Could you try to print tmp with and without quiet?
>>> http://trac.osgeo.org/grass/browser/grass-addons/grass7/
>>> vector/v.fixed.segmentpoints/v.fixed.segmentpoints.py#L102
>>> 102 # Read length
>>> 103 tmp = grass.read_command('v.to.db', map = voutline,
>>> 104 type = 'line',
>>> 105 layer = 1,
>>> 106 qlayer = 1,
>>> 107 option = 'length',
>>> 108 units = 'meters',
>>> 109 column = 'vlength',
>>> 110 flags = 'p')
>>> 111 vector_line_length = float(tmp.split('\n')[1].split('|')[1])
>>> 112
>>> 113 # Print vector line length
>>> 114 grass.message( "Vector line length in meter:" )
>>> 115 grass.message( vector_line_length )
>>> 116 grass.message( "----" )
>>> it's just to get the length of the vector line for further calculations:
>>> in normal and verbose mode:
>>> Lese Objekte...
>>> 58858.3366368
>>> as Moritz points out, it seems quiet mode suppresses the access to the
>>> output of grass.read_command; his solution/workaround with GRASS_VERBOSE
>>> env
>>> variable seems not to work here on my side.
>> I'm afraid that --quiet supersedes any settings in the code, but am not
>> sure.
> So how about setting quiet=False when calling v.to.db? Anyway I don't
> think quiet causes read_command to be completely silent, just run
> grass.read_command('r.info', map='elevation', flags='g', quiet=True)
> and it gives output as expected.
It's because of the header line:
cat|length
1|572.767146965659
but in quiet mode you get:
1|572.767146965659
so I would suggest set quiet=True for v.to.db and change the code for
parsing to expect just one line.
Anna
>> Moritz
>> grass-dev mailing list
>> grass-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141114/9fec4b0c/attachment.html>
