[GRASS-dev] epsg code stored anywhere and used by v.out.ogr/r.out.gdal?
Helmut Kudrnovsky
hellik at web.de
Sun Nov 16 02:37:42 PST 2014
>> if yes can be the epsg-code-representation of the projection used by
>> v.out.ogr/r.out.gdal instead of the grass gis representation of the
>> projection?
>Often not since it may lack datum parameters.
a quick test case:
data available at
https://www.tirol.gv.at/data/datenkatalog/umwelt/gewaessernetz/ is in
EPSG:8.2:31254
the prj-file of this dataset says:
Gesamtgewaessernetz_v10_1_Tirol.prj:
PROJCS["MGI_Austria_GK_West",
GEOGCS["GCS_MGI",
DATUM["D_MGI",
SPHEROID["Bessel_1841",6377397.155,299.1528128]],
PRIMEM["Greenwich",0.0],
UNIT["Degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["False_Easting",0.0],
PARAMETER["False_Northing",-5000000.0],
PARAMETER["Central_Meridian",10.33333333333333],
PARAMETER["Scale_Factor",1.0],
PARAMETER["Latitude_Of_Origin",0.0],
UNIT["Meter",1.0]]
http://epsg.io/31254 says
OGC WKT
PROJCS["MGI / Austria GK West",
GEOGCS["MGI",DATUM["Militar_Geographische_Institute",
SPHEROID["Bessel 1841",6377397.155,299.1528128,
AUTHORITY["EPSG","7004"]],
TOWGS84[577.326,90.129,463.919,5.137,1.474,5.297,2.4232],
AUTHORITY["EPSG","6312"]],
PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4312"]],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",10.33333333333333],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",-5000000],
UNIT["metre",1,AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","31254"]]
ESRI WKT
GEOGCS["GCS_MGI",DATUM["D_MGI",
PRIMEM["Greenwich",0],
UNIT["Degree",0.017453292519943295]],
UNIT["Meter",1]]
creating a grass location with EPSG:31254, import the shapefile above and
export it by v.out.ogr with/without option -e
voutogr.prj:
PROJCS["Transverse_Mercator",
GEOGCS["GCS_bessel",
DATUM["D_Militar_Geographische_Institut",
UNIT["Meter",1]]
voutogr_option_e.prj:
UNIT["Meter",1]]
I know that all these several projection representations are correct and
define all the same projection.
IMHO at least a v.out.ogr option, which considers the EPSG representation
(e.g. PROJCS["MGI_Austria_GK_West", ... or PROJCS["MGI / Austria GK West",
...), would be nice.
any opinion?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/epsg-code-stored-anywhere-and-used-by-v-out-ogr-r-out-gdal-tp5173171p5173184.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
