[GRASS-dev] [GRASS GIS] #2490: EPSG code not saved in PROJ_EPSG
GRASS GIS trac at osgeo.org
Sun Nov 16 04:55:03 PST 2014
 Reporter:  hellik   |       Owner:  grass-dev@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  7.0.0
Component:  Default  |     Version:  unspecified
 Keywords:           |    Platform:  MSWindows 7
      Cpu:  x86-64   |
 from the ML
 http://lists.osgeo.org/pipermail/grass-dev/2014-November/071807.html
 > It is sometimes stored in the PROJ_INFO file.
 in the recent versions of GRASS 7 it should be stored in PROJ_EPSG
 file. If not than it's a bug.
 tested here with
 GRASS Version: 7.1.svn
 GRASS SVN Revision: 62754
 Erstellungsdatum: 2014-11-16
 Build Platform: i686-pc-mingw32
 GDAL/OGR: 1.11.0
 PROJ.4: 4.8.0
 GEOS: 3.4.2
 SQLite: 3.7.17
 Python: 2.7.4
 wxPython: 2.8.12.1
 Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
 location wizard -> create location by epsg code (e.g. 4326)
 EPSG code is not saved in PROJ_EPSG
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490>
