[GRASS-dev] [GRASS-SVN] r62566 - in grass/trunk: gui/wxpython/vdigit lib/python/exceptions lib/python/script lib/python/temporal scripts/d.shadedmap scripts/db.dropcolumn scripts/db.in.ogr scripts/db.out.ogr scripts/db.test scripts/g.extension.all scripts/i.in.spotvgt scripts/r.fillnulls scripts/r.grow scripts/r.in.srtm scripts/r.in.wms scripts/r.mask scripts/r.out.xyz scripts/r3.in.xyz scripts/v.build.all scripts/v.convert.all scripts/v.db.addtable scripts/v.db.dropcolumn scripts/v.db.droprow scripts/v.db.droptable scripts/v.db.join scripts/v.db.reconnect.all scripts/v.dissolve scripts/v.in.e00 scripts/v.in.gps scripts/v.in.mapgen scripts/v.in.wfs scripts/v.out.gps scripts/v.rast.stats scripts/v.to.lines scripts/v.unpack scripts/v.what.vect temporal/t.rast.colors temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.vect.observe.strds temporal/t.vect.what.strds
Vaclav Petras
wenzeslaus at gmail.com
Mon Nov 17 07:28:30 PST 2014
On Mon, Nov 17, 2014 at 10:03 AM, Markus Neteler <neteler at osgeo.org> wrote:
> Do you plan to backport this (and related) fixes?
> Yes. I guess I should do it ASAP. With Anna we have already prepared patch
for addons. I was waiting for some problems such as the one with
grass.script.core.message() to appear. Now it seems that it is settled
well. I have used few functions in GUI recently too, so most of the code
should be OK now. There are few issues here and there but it should be only
replacing one error message by another. I will try to do it today or
tomorrow.
However, there are also the basename/multiple inputs/outputs related
changes which are not done yet and should go to 7.0. I'm uncomfortable with
doing this last minute change but the improvements would be significant.
Vaclav
On Mon, Nov 3, 2014 at 6:32 AM, <svn_grass at osgeo.org> wrote:
> > Author: wenzeslaus
> > Date: 2014-11-02 21:32:32 -0800 (Sun, 02 Nov 2014)
> > New Revision: 62566
> > Modified:
> > grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
> > grass/trunk/lib/python/exceptions/__init__.py
> > grass/trunk/lib/python/script/array.py
> > grass/trunk/lib/python/script/core.py
> > grass/trunk/lib/python/script/db.py
> > grass/trunk/lib/python/script/raster.py
> > grass/trunk/lib/python/script/raster3d.py
> > grass/trunk/lib/python/temporal/aggregation.py
> > grass/trunk/lib/python/temporal/extract.py
> > grass/trunk/lib/python/temporal/mapcalc.py
> > grass/trunk/lib/python/temporal/stds_export.py
> > grass/trunk/lib/python/temporal/stds_import.py
> > grass/trunk/scripts/d.shadedmap/d.shadedmap.py
> > grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
> > grass/trunk/scripts/db.in.ogr/db.in.ogr.py
> > grass/trunk/scripts/db.out.ogr/db.out.ogr.py
> > grass/trunk/scripts/db.test/db.test.py
> > grass/trunk/scripts/g.extension.all/g.extension.all.py
> > grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
> > grass/trunk/scripts/r.fillnulls/r.fillnulls.py
> > grass/trunk/scripts/r.grow/r.grow.py
> > grass/trunk/scripts/r.in.srtm/r.in.srtm.py
> > grass/trunk/scripts/r.in.wms/wms_base.py
> > grass/trunk/scripts/r.mask/r.mask.py
> > grass/trunk/scripts/r.out.xyz/r.out.xyz.py
> > grass/trunk/scripts/r3.in.xyz/r3.in.xyz.py
> > grass/trunk/scripts/v.build.all/v.build.all.py
> > grass/trunk/scripts/v.convert.all/v.convert.all.py
> > grass/trunk/scripts/v.db.addtable/v.db.addtable.py
> > grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
> > grass/trunk/scripts/v.db.droprow/v.db.droprow.py
> > grass/trunk/scripts/v.db.droptable/v.db.droptable.py
> > grass/trunk/scripts/v.db.join/v.db.join.py
> > grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
> > grass/trunk/scripts/v.dissolve/v.dissolve.py
> > grass/trunk/scripts/v.in.e00/v.in.e00.py
> > grass/trunk/scripts/v.in.gps/v.in.gps.py
> > grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
> > grass/trunk/scripts/v.in.wfs/v.in.wfs.py
> > grass/trunk/scripts/v.out.gps/v.out.gps.py
> > grass/trunk/scripts/v.rast.stats/v.rast.stats.py
> > grass/trunk/scripts/v.to.lines/v.to.lines.py
> > grass/trunk/scripts/v.unpack/v.unpack.py
> > grass/trunk/scripts/v.what.vect/v.what.vect.py
> > grass/trunk/temporal/t.rast.colors/t.rast.colors.py
> > grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
> > grass/trunk/temporal/t.rast.series/t.rast.series.py
> > grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
> > grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
> > grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
> > Log:
> > pythonlib: raise exceptions from run_command and others (#2326)
> > * run_command and write_command are raising exception instead of
> returning subprocess retrun code
> > * read_command is raising instead of being silent in case of error
> (same for parse_command)
> > * code using/checking return code changed to try-except, rest left as
> it was
> > * basic functions in GUI and tests are running
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141117/58f82253/attachment.html>
