[GRASS-dev] [GRASS-SVN] r62566 - in grass/trunk: gui/wxpython/vdigit lib/python/exceptions lib/python/script lib/python/temporal scripts/d.shadedmap scripts/db.dropcolumn scripts/db.in.ogr scripts/db.out.ogr scripts/db.test scripts/g.extension.all scripts/i.in.spotvgt scripts/r.fillnulls scripts/r.grow scripts/r.in.srtm scripts/r.in.wms scripts/r.mask scripts/r.out.xyz scripts/r3.in.xyz scripts/v.build.all scripts/v.convert.all scripts/v.db.addtable scripts/v.db.dropcolumn scripts/v.db.droprow scripts/v.db.droptable scripts/v.db.join scripts/v.db.reconnect.all scripts/v.dissolve scripts/v.in.e00 scripts/v.in.gps scripts/v.in.mapgen scripts/v.in.wfs scripts/v.out.gps scripts/v.rast.stats scripts/v.to.lines scripts/v.unpack scripts/v.what.vect temporal/t.rast.colors temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.vect.observe.strds temporal/t.vect.what.strds
Markus Neteler neteler at osgeo.org
Mon Nov 17 07:40:47 PST 2014
On Mon, Nov 17, 2014 at 4:28 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> However, there are also the basename/multiple inputs/outputs related changes
> which are not done yet and should go to 7.0. I'm uncomfortable with doing
> this last minute change but the improvements would be significant.
We are not in freeze but preparing beta4, so no problem.
Better getting improvements in rather than postpone them to GRASS GIS 8...
My 0.02 cents,
Markus
