[GRASS-dev] [GRASS GIS] #2494: d.vect.thematic broken
GRASS GIS trac at osgeo.org
Tue Nov 18 09:36:44 PST 2014
 Reporter:  neteler                   |       Owner:  grass-dev@…
     Type:  defect                    |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  Display                   |     Version:  svn-releasebranch70
 Keywords:  d.vect.thematic, d.graph  |    Platform:  Linux
      Cpu:  Unspecified               |
 Using the NC Example from
 http://grass.osgeo.org/grass70/manuals/d.vect.thematic.html#examples
 one gets:
 ... [all ok]...
 GRASS 7.1.svn (nc_spm_08_grass7):~ > v.univar -e elev_sample col=diff
 type=point
 number of features with non NULL attribute: 200
 number of missing attributes: 0
 number of NULL attributes: 0
 minimum: -26.8796
 maximum: 21.2874
 range: 48.167
 GRASS 7.1.svn (nc_spm_08_grass7):~ > d.mon wx0
 GRASS 7.1.svn (nc_spm_08_grass7):~ > d.vect.thematic -l elev_sample
 column=diff type=point
 Thematic map legend for column diff of map elev_sample
 Value range: -26.8796 - 21.2874
 Mapped by 4 intervals of 12.04175
 Color(R:G:B)    Value
 0:0:255         -26.8796 - 21.2874
 d.vect complete.
 85:0:170                -26.8796 - 21.2874
 d.vect complete.
 170:0:85                -26.8796 - 21.2874
 d.vect complete.
 GRASS 7.1.svn (nc_spm_08_grass7):~ > Command 'd.graph color=black
 input=/home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0'
 failed
 Details: Graph file
 </home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0>
 not found
 The file names are indeed different:
 ls /home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/
 23101.0.cmd  23101.0.env  23101.0.ppm.ppm
Ticket URL: <http://trac.osgeo.org/grass/ticket/2494>
