[GRASS-dev] [GRASS GIS] #2494: d.vect.thematic broken
trac at osgeo.org
Wed Nov 19 00:49:54 PST 2014
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Display | Version: svn-releasebranch70
Keywords: d.vect.thematic, d.graph | Platform: Linux
Cpu: Unspecified |
Comment(by mlennert):
Replying to [ticket:2494 neteler]:
> Using the NC Example from
> http://grass.osgeo.org/grass70/manuals/d.vect.thematic.html#examples
> one gets:
> ... [all ok]...
> GRASS 7.1.svn (nc_spm_08_grass7):~ > v.univar -e elev_sample col=diff
type=point
> number of features with non NULL attribute: 200
> number of missing attributes: 0
> number of NULL attributes: 0
> minimum: -26.8796
> maximum: 21.2874
> range: 48.167
> GRASS 7.1.svn (nc_spm_08_grass7):~ > d.mon wx0
> GRASS 7.1.svn (nc_spm_08_grass7):~ > d.vect.thematic -l elev_sample
column=diff type=point
> Thematic map legend for column diff of map elev_sample
> Value range: -26.8796 - 21.2874
> Mapped by 4 intervals of 12.04175
> Color(R:G:B) Value
> 0:0:255 -26.8796 - 21.2874
> d.vect complete.
> 85:0:170 -26.8796 - 21.2874
> d.vect complete.
> 170:0:85 -26.8796 - 21.2874
> d.vect complete.
> GRASS 7.1.svn (nc_spm_08_grass7):~ > Command 'd.graph color=black
input=/home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0'
failed
> Details: Graph file
</home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0>
not found
I see the same message without the '-l' flag and am a bit stumped about
where this comes from. In d.vect.thematic.py the only call to d.graph
happens if the '-l' flag is set, so this message do not seem to come from
the module itself. <wild guess>Could it be the wx0 monitor that tries to
call the file after d.vect.thematic itself has closed and erased its temp
files ?</wild guess>
Moritz
Ticket URL: <http://trac.osgeo.org/grass/ticket/2494#comment:1>
