[GRASS-dev] planning grass 7.0.0beta4
Vaclav Petras wenzeslaus at gmail.com
Thu Nov 20 17:47:52 PST 2014
On Thu, Nov 20, 2014 at 5:40 PM, Sören Gebbert <soerengebbert at googlemail.com
> wrote:
> since most of
> them are tested using the test suite.
There are three tests failing. One of them is slightly mystified by strange
r3.univar output (none in fact). The other is shell script.
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-20-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.to.rast3/test_strds_to_rast3/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-20-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.algebra/test_raster_algebra_granularity/index.html
http://fatra.cnr.ncsu.edu/grassgistests/reports_for_date-2014-11-20-08-00/report_for_nc_spm_08_grass7_nc/temporal/t.rast.accumulate/test.t.rast.accumulate/index.html
But anyway, temporal framework is probably the most (automatic) test
covered part of GRASS.
I'm still not sure about the backport. I was not able to work on some
things such as Python 2.6 support yet. Perhaps target for RC1 rather than
beta4?
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141120/6f32d89a/attachment.html>
