[GRASS-dev] planning grass 7.0.0beta4
Sören Gebbert
soerengebbert at googlemail.com
Sat Nov 22 15:54:32 PST 2014
Backport done in r62858 - r62867.
I hope everything works fine.
It would be great if we could automatically test all the changes that
i have introduced in the release branch using the testsuite.
A "make distclean" is needed.
Best regards
Soeren
2014-11-20 23:40 GMT+01:00 Sören Gebbert <soerengebbert at googlemail.com>:
> 2014-11-20 23:18 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
>> Hi,
>> On Fri, Nov 14, 2014 at 4:31 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> Hi all,
>>> http://trac.osgeo.org/grass/wiki/Grass7Planning#Planningongoing
>>> the only (?) remaining outstanding missing backport is the temporal framework...
>>> What do you plan, Soeren?
> Oh, uh, no, i missed that. So the testsuite has been backported as well?
>> for the time being I have updated the temporal manual with a selective
>> sync to trunk in r62842.
>> Probably that's it for beta4? Time flies..
> I will start backporting tomorrow, probably all changes, since most of
> them are tested using the test suite.
> Best regards
> Soeren
>> Markus
