[GRASS-dev] [GRASS GIS] #2456: read CSV from GDAL data directory
trac at osgeo.org
Mon Nov 24 08:22:56 PST 2014
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: critical | Milestone: 7.1.0
Component: Projections/Datums | Version: unspecified
Keywords: gdal | Platform: Unspecified
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:3 martinl]:
> For record list of affected files:
> * pcs.csv
The attached patch attachment:gdal_data.diff forces GRASS to use CSV files
from GDAL. First found problem:
GRASS defines 5514 as
pcs.csv:5514,"S-JTSK / Krovak East
North",9001,4818,19952,9819,1,0,6501,8806,0,9001,8807,0,9001,8811,49.3,9110,8813,30.1717303,9110,8818,78.3,9110,8819,0.9999,9201,8833,42.3,9110
g.proj epsg=5514 -p
-PROJ_INFO-------------------------------------------------
proj : krovak
datum : hermannskogel
ellps : bessel
lat_0 : 49.5
lon_0 : 42.5
alpha : 30.28813972222222
k : 0.9999
x_0 : 0
y_0 : 0
pm : ferro
no_defs : defined
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
GDAL as
North",9001,4156,5510,1041,1,0,4499,1036,30.1717303,9110,8806,0,9001,8807,0,9001,8811,49.3,9110,8818,78.3,9110,8819,0.9999,9201,8833,24.5,9110
.proj epsg=5514 -p
proj : krovak
ellps : bessel
lat_0 : 49.5
lon_0 : 24.83333333333333
k : 0.9999
x_0 : 0
y_0 : 0
towgs84 : 589,76,480,0,0,0,0
no_defs : defined
unit : meter
units : meters
meters : 1
The `wgs84` causes that
g.proj epsg=5514 datum_trans=-1
ERROR: No output format specified, define one of flags -p, -g, -j, or -w
will not work.
Should be:
1
Used in whole hermannskogel region
towgs84=653.000,-212.000,449.000
Default 3-Parameter Transformation (May not be optimum for older datums;
use this only if no more appropriate options are available.)
2
Used in Austria
towgs84=577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
Accuracy approx. 1.5m
3
Used in Czech Republic
towgs84=570.8,85.7,462.8,4.998,1.587,5.261,3.56
4
Used in Slovakia
towgs84=485.021,169.465,483.839,7.786342,4.397554,4.102655,0
5
Used in Slovenia
towgs84=426.9,142.6,460.1,4.91,4.49,-12.42,17.1
Ticket URL: <http://trac.osgeo.org/grass/ticket/2456#comment:6>
