[GRASS-dev] [GRASS GIS] #2343: GRASS 7: "inf" values break insert statements in v.rast.stats
trac at osgeo.org
Tue Nov 25 02:55:40 PST 2014
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.0
Component: Python | Version: svn-releasebranch70
Keywords: v.rast.stats | Platform: All
Cpu: All |
Comment(by lucadelu):
Replying to [ticket:2343 sbl]:
> When running v.rast.stats on a dataset with small geometries (which in
my case were represented by 2 pixels in the raster), the parameter
"coeff_var" can result in "inf" value.
> "inf" breaks the INSERT statement and results in an DBMI error "no such
column: inf", which at the end crashes v.rast.stats.
> Just like "nan", "inf" could be replaced by NULL. Changing line 263 in
v.rast.stats.py into this:
> if value.lower().endswith('nan') or value.lower().endswith('inf'):
> should work.
> Both GRASS 7.0 and 7.1 are affected. Please find attached patches for
both versions...
Could you provide a dataset to test the patches?
Thanks
Ticket URL: <http://trac.osgeo.org/grass/ticket/2343#comment:4>
