[GRASS-dev] grass with LASzip
Anna Petrášová
kratochanna at gmail.com
Tue Nov 25 06:04:51 PST 2014
On Tue, Nov 25, 2014 at 2:54 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> On 25 November 2014 at 02:19, Anna Petrášová <kratochanna at gmail.com>
> wrote:
> > I did that. I didn't have problems until now when compiling grass with
> > libLAS, but in order to read laz file, I had to compile libLAS with
> LASzip
> > support and that's what causing the problem, as can be seen from the
> error I
> > got (missing liblaszip.so.6). LibLAS can be configured in grass, so it
> seems
> > that we should be able to specify LASzip library in configure too. It's
> > possible I did something wrong so I was wondering if anyone else was
> trying
> > to do the same.
> Anna did you recompile libLAS after compile LASzip?
> You have not to specify LASzip library in the GRASS configure but in
> the libLAS one.
Of course I recompiled libLAS and I did specify where to look for LASzip,
but it doesn't seem to be enough in my case. I assume, you don't have any
problems?
> > Anna
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141125/a90239ed/attachment-0001.html>
