[GRASS-dev] grass with LASzip
Luca Delucchi
lucadeluge at gmail.com
Mon Nov 24 23:54:29 PST 2014
On 25 November 2014 at 02:19, Anna Petrášová <kratochanna at gmail.com> wrote:
> I did that. I didn't have problems until now when compiling grass with
> libLAS, but in order to read laz file, I had to compile libLAS with LASzip
> support and that's what causing the problem, as can be seen from the error I
> got (missing liblaszip.so.6). LibLAS can be configured in grass, so it seems
> that we should be able to specify LASzip library in configure too. It's
> possible I did something wrong so I was wondering if anyone else was trying
> to do the same.
Anna did you recompile libLAS after compile LASzip?
You have not to specify LASzip library in the GRASS configure but in
the libLAS one.
> Anna
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
