[GRASS-dev] [GRASS GIS] #580: WinGRASS: $GISBASE/etc/gui/scripts/ require something like $(EXE) to run
trac at osgeo.org
Wed Nov 26 09:42:58 PST 2014
Reporter: hamish | Owner: grass-dev@…
Type: defect | Status: reopened
Priority: blocker | Milestone: 7.0.0
Component: wxGUI | Version: svn-trunk
Resolution: | Keywords: wingrass
Platform: MSWindows XP | Cpu: Unspecified
Comment(by martinl):
Replying to [comment:57 martinl]:
> Replying to [comment:55 hellik]:
> > suggest to close the ticket as scripts are now working in winGRASS. at
least downgrading priority if ticket should stay open.
> before that we need to fix makefiles to produce also bat files from
`g.gui.*` modules and GUI scripts (see my comment above).
done in r62956, but it's not working - attempt to launch `g.gui.animation`
from cmdline:
C:\>Traceback (most recent call last):
File "<string>", line 1, in <module>
File "C:\OSGEO4~1\apps\Python27\lib\multiprocessing\forking.py", line
381, in
main
self = load(from_parent)
File "C:\OSGEO4~1\apps\Python27\lib\pickle.py", line 1378, in load
return Unpickler(file).load()
File "C:\OSGEO4~1\apps\Python27\lib\pickle.py", line 858, in load
dispatch[key](self)
File "C:\OSGEO4~1\apps\Python27\lib\pickle.py", line 1090, in
load_global
klass = self.find_class(module, name)
File "C:\OSGEO4~1\apps\Python27\lib\pickle.py", line 1124, in find_class
__import__(module)
File
"C:\OSGEO4~1\apps\grass\grass-7.1.svn\etc\python\grass\temporal\__init__.
py", line 28, in <module>
from temporal_algebra import *
File
"C:\OSGEO4~1\apps\grass\grass-7.1.svn\etc\python\grass\temporal\temporal_
algebra.py", line 450, in <module>
import grass.pygrass.modules as pymod
File
"C:\OSGEO4~1\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\modules\__
init__.py", line 2, in <module>
from grass.pygrass.modules.interface import Module,
ParallelModuleQueue
File
"C:\OSGEO4~1\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\modules\in
terface\__init__.py", line 9, in <module>
from grass.pygrass.modules.interface import module
File
terface\module.py", line 297, in <module>
class Module(object):
File
terface\module.py", line 700, in Module
@mdebug(1, extra=_get_bash)
File
terface\module.py", line 36, in mdebug
msgr = get_msgr()
File
"C:\OSGEO4~1\apps\grass\grass-7.1.svn\etc\python\grass\pygrass\messages\_
_init__.py", line 352, in get_msgr
_instance[0] = Messenger(*args, **kwargs)
File
_init__.py", line 175, in __init__
self.start_server()
File
_init__.py", line 185, in start_server
self.server.start()
File "C:\OSGEO4~1\apps\Python27\lib\multiprocessing\process.py", line
130, in
start
self._popen = Popen(self)
258, in
__init__
cmd = get_command_line() + [rhandle]
358, in
get_command_line
is not going to be frozen to produce a Windows executable.''')
RuntimeError:
Attempt to start a new process before the current process
has finished its bootstrapping phase.
Ticket URL: <http://trac.osgeo.org/grass/ticket/580#comment:60>
