[GRASS-dev] G7: turning manual page examples into test cases
Moskovitz, Bob@DOC
Bob.Moskovitz at conservation.ca.gov
Wed Nov 26 09:30:10 PST 2014
This almost sound like the PostGIS Garden Test: http://trac.osgeo.org/postgis/wiki/DevWikiGardenTest
Robert Moskovitz
California Geological Survey
Seismic Hazards Zonation Program
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
-----Original Message-----
From: grass-dev-bounces at lists.osgeo.org [mailto:grass-dev-bounces at lists.osgeo.org] On Behalf Of Markus Neteler
Sent: Wednesday, November 26, 2014 7:45 AM
To: GRASS developers list
Subject: [GRASS-dev] G7: turning manual page examples into test cases
in the recent past I added a series of examples to various manual
pages. Most of them might qualify for (basic) testing of the
respective command.
Since it is a bit time consuming to write these standard tests
manually, would there be a chance to develop a test case generator
e.g. driven by a template?
Markus
grass-dev mailing list
grass-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-dev
