[GRASS-dev] sample vector temporal data
Anna Petrášová
kratochanna at gmail.com
Wed Nov 26 11:22:25 PST 2014
On Wed, Nov 26, 2014 at 12:10 PM, Luca Delucchi <lucadeluge at gmail.com>
wrote:
> On 8 October 2014 at 03:21, Anna Petrášová <kratochanna at gmail.com> wrote:
> > Hi,
> Hi,
> > as you know we need to decide which data are we going to use for t.vect.*
> > examples. One possibility is to use oceanfront shorelines of North
> Carolina,
> > we can get this data easily from here:
> > http://portal.ncdenr.org/web/cm/download-spatial-data-maps-oceanfront
> > It includes these years, interval data in case of older data, and
> instance
> > data from the past years:
> > 1849 - 1873, 1925 - 1946, 1933 - 1952, 1940 - 1962, 1970 - 1988, 1997,
> 1998,
> > 2003, 2004, 2009
> > The advantage is that the data is public and basically ready to use. If
> we
> > decide to use it, should we include the entire NC shoreline or just some
> > detail (look at the attachment)?
> > In addition, we can also create a vector time-series where the geometry
> is
> > not changing, just the attribute changes (derived from the climate data
> for
> > example).
> > Any thoughts on this?
> After some weeks without any comments I think we could proceed to
> create the dataset.
> > By the way, the climate dataset seems to be fine, we got the
> confirmation we
> > can use it, it is not subject to the PRISM licence since it was
> interpolated
> > at NC State Climate Office.
> I would like to work on it and on temporal documentation in the next
> two days, so what do you think about this plan starting from the
> sample data for the temporal workshop [0]?
> - remove some years from climate_2000_2012 data, for example keep no
> more that 5 years, because right know the location is a little bit
> heavy (about 700MB) and for documentation 5 years should be fine.
I agree.
> - create vector for static temporal dataset from towns querying the
> rasters in climate_2000_2012 to create something like virtual weather
> stations
yes, but there are no NC towns as points in the standard dataset. You could
use precip_30ynormals at PERMANENT which are the meteorology stations, which
probably doesn't make much sense since but maybe it's still good for the
dataset.
- add the shoreline ocean data, maybe in a new mapset
Helena suggests here to select a smaller, dynamic area (some cape for
example) and also provide a DEM and ortho for that area (elev_lid792 is not
coastal) to get some context. I am not sure about this dataset, if it's
really needed, because I don't know what kind of temporal vector analysis
we could show in the manual. It could be a good dataset to show how to
create animations. If we decide to do it, I can help you with this part.
Another option is to derive contours from the temperature/precipitation
dataset. The advantage is that's easier to prepare.
- create at least one temporal dataset for each type (strds, str3ds, stvds)
Do we have any temporal data for 3d raster? I don't think we necessarily
have to create this dataset.
Anna
- update the temporal documentation according the new dataset.
> what do you think?
> Helena in her answer was speaking about orthophoto and DEM for the
> shoreline ocean data, are this data already inside the location
> (elev_lid792_1m,elev_state_500m,ortho_t792_1m) ?
> > Anna
> [0] http://fatra.cnr.ncsu.edu/temporal-grass-workshop/
> ciao
> Luca
> http://gis.cri.fmach.it/delucchi/
> www.lucadelu.org
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141126/103c5f86/attachment.html>
